Reverse Telnet over AUX Port
mohammedmahmoud Tue, 04/15/2008 - 11:04
  • Green, 3000 points or more
Hi Stephan,
Yes, but you need to know the pin assignment and the appropriate baud rate.
BR,
Mohammed Mahmoud.
Hi Mohammed,
the baud rate is 9600 und a normal Cisco Console Cable works on the console port of the console server.
I used an normal Cisco Console Cable and a rolled Cable for the connection between the Cisco 2821 and the Lantronix Console Server.
But it doesn't work with "telnet 2001".....the AUX Port is Line 1.
This is the current config from the aux port:
interface Loopback0
ip address 192.168.1.254 255.255.255.0
line aux 0
modem InOut
transport input all
speed 9600
stopbits 1
Best regards,
Stephan Brunst
mohammedmahmoud Tue, 04/15/2008 - 13:10
Stephan,
Can you please try to add "no exec" under the line aux 0, then clear the line a couple of times and try again.
BR,
Mohammed Mahmoud.
aclaughan Tue, 04/15/2008 - 22:46
The
modem InOut
is not required..
add
no exec
you might need to clear the line and hit return once connected.
Alan
