Header based websites behind PIX 501 not working
Apr 15th, 2008
I am not sure what to setup for this. I have a linux box running ISPConfig which allows you to put several websites on one single IP address. If I have a public IP on it, they work just fine, but if I put a PIX in front of it and static map 1:1 with an ACL for port 80, all I get is the default sharedip page. It is as if the server isnt seeing the URL in the packet stream. Is there something on the PIX that is stripping it out?
