pix firewall site to site VPN
Apr 15th, 2008
I set up an IPSEC VPN tunnel between two pix firewalls 515 and 535 . I am able to ping between the hosts behind each pix firewall but i am not able to open or browse to any share . Workstation are windows xp. thanks for your help
Richard Bradfield Wed, 04/16/2008 - 01:01
  • Silver, 250 points or more
do you want to post the config, then we can see whats happening
bamnocadmin Wed, 04/16/2008 - 10:15
Check if your ACL is blocking VPN traffic.
Try sysopt connection permit-ipsec to allow VPn traffic to get around your ACLs.
Post your config.
Thanks.
Aidswailem Wed, 04/16/2008 - 11:37
Thanks for your reply , i solved the problem it was a windows firewall issue.
Thanks again.
