Expired CCNP
Apr 15th, 2008
If your CCNP expires, and you want to re-certify. Do you have to retake your CCNA tests, then certify CCNP or can you just start out by taking your CCNP series of tests
scottmac Tue, 04/15/2008 - 18:59
If it's expired, then you start from scratch, as if you never had it.
It's possible that your CCNA is still valid, but if it's not, you'll have to do that too, because it's a prerequisite for the CC*P.
It doesn't matter what order you take any of them in, they just all have to be done to get the cert (including CCNA).
Good Luck
Scott
