Richard Burts Wed, 04/16/2008 - 03:31
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Steve
Which version of the 5.0 client?
Does the client connect and authenticate or does it lose contact before authentication?
If it does authenticate is it getting assigned an IP address? Does it run for a while and then lose contact or is the failure immediate?
Rick
steveskotak Wed, 04/16/2008 - 08:14
it is version 5.0.00.0340
the client will (appears)to connect and authenticate. not sure if a IP address is assigned. How do I check?
I believe that it never really connects.
Richard Burts Wed, 04/16/2008 - 08:22
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Steve
The easy way to check for IP address assignment is to do (at a command prompt on the PC) ipconfig to see what address is assigned before connecting, then connect, then do another ipconfig and see if another address is indicated.
Rick
