IP PHONE 7906G NOT STARTING UP
Apr 15th, 2008
My 7906g phone is not comming up once power is connected. The led indicators just flash twice then go off and there is no display on the LCD screen. any Help?
amos.ugwu Wed, 04/16/2008 - 01:20
If you have configured your ccme router with the required information and other ip phones series are working well but the 7906 is not working well, it means you have to load the firmware files for 7906 in the ccme router. Download the firmware files from cisco sites and use the load command to load them on the ccme router.After the loading, reload the router
