Cisco LMS 3.0 DFM in Learning State (Always)
Apr 16th, 2008
Very recently i have installed LMS 3.0
Data collection is fine.I am having problem with DFM.DFM is always in learning state.Any advice will be appriciated.
Original Platform: Windows server 2003 SP2 with all windows update + LMS update to dec 2007 + patches
Then redueced to SP1 , removed .net framework 2 & 3 , still no luck.
The bug is CSCsm04957:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsm04957
How To confirm if you are facing this:
(*) If your DFM reports 10% stuck issue in DFM for windows 2003 platform,
search for DLLs(msvcm80.dll, msvcp80.dll, msvcr80.dll) in the entire
system. You are likely to see more than one copy of these DLLs
(*) Check for the version of dlls above.
(*) If any of the version is different from 8.00.50727.42, the issue will occur.
Using listdlls.exe from www.sysinternals.com you can confirm if a CW process is in fact using that dll. Place the attached dll in: CSCOpx\objects\smarts\lib
