VRF-Lite Help needed
awickers
Hi given this is my first post please excuse any glaring errors,
My problem is I am having issues reaching the internet from our 3845 router using
VRF the setup is as follows
I have a 3845 router with a DS3 Cct connected to my provider. One T3 sub-interface goes to our providers MPLS cloud and then to our other offices. The other subinterface on the T3 is connected to our Providers Internet service, the 3845 has two LAN interfaces G0/0 & G0/1.
G0/0 is connected to our Local LAN and is our office default G/W. G0/1 is currently configured with a temporary Internet Address for testing purposes.
BGP is running between the 3845 and the providers PE router for MPLS cloud connectivity. BGP is also running between our 3845 and PE router for Internet connectivity. I have already implemented filtering on the BGP config that stops updates for the Internet subnet appearing on the MPLS network and the other way round stopping the updates for the MPLS routes appearing on the Internet subnet.
I have implemented VRF to ensure traffic separation between the internal and internet traffic but the Internet traffic does not flow between G0/1 and the internet, any help would be gratefully received.
Router config available as soon as someone requests it
Andrew
You need to modify your BGP config. For the DIA vrf you need to create an address-family under your BGP config for the Internet Peering. This way you should not need to filter between the 2 BGP peerings although i can't tell from your config how the BGP routes are getting redistributed into your local routing protocol (if at all).
So your BGP config would be something along the lines of
router bgp 64610
no synchronization
bgp log-neighbor-changes
network 10.z.z.z mask 255.255.240.0 --> Office LAN subnet
redistribute static
neighbor x.x.x.x remote-as 6745  MPLS peering
neighbor x.x.x.x ebgp-multihop 4
neighbor x.x.x.x version 4
neighbor x.x.x.x distribute-list 10 out
no auto-summary
address-family ipv4 vrf DIA
neighbor y.y.y.y remote-as 3549  Internet peering
neighbor y.y.y.y version 4
network 208.50.120.32 mask 255.255.255.224
Not sure where you want to redistribute static so i have left it in the main BGP config.
The main BGP config is for your internal network. The address-family is for your DIA vrf.
Jon
12 Replies 12
Jon Marshall
Could you provide a few more details plus config.
1) What vrf have you assigned Gi0/1 into.
2) What vrf is gi0/2 in.
3) Have you allocated your T3 subinterfaces into vrf's ?
What traffic flows ie. internal to external and vice-versa are you trying to segregate.
Jon
Jon
Thanks for the prompt reply the config has the answers to question 1, 2 & 3.
The traffic segregation needed is as follows
Gi0/0 <-> s2/0.16 for internal traffic
Gi0/1 <-> S2/0.518 for Internet traffic.
Behind the Gi0/1 interface is a Checkpoint firewall cluster and various web servers etc. so all Internet traffic from internal users etc would first come via the internal interface of the Checkpoint and then to the Gi0/1 interface.
Hope this make sense.
Regards Andrew
3845 config
ip vrf DIA
description *** DIA VRF Instance ***
rd 3549:2
route-target export 3549:2
route-target import 3549:2
interface GigabitEthernet0/1
description *** Local Internet Connection ***
ip vrf forwarding DIA
ip address 208.50.120.33 255.255.255.224
interface Serial2/0.518 point-to-point
description ***** Internet Connection ****
bandwidth 12000
ip address 207.138.94.182 255.255.255.252
frame-relay interface-dlci 518
router bgp 64610
no synchronization
network 208.50.120.32 mask 255.255.255.224 --> Test IP subnet
redistribute static
neighbor y.y.y.y local-as 64875
neighbor y.y.y.y prefix-list DIA-out out
no auto-summary
ip route 0.0.0.0 0.0.0.0 10.z.z.z
ip route vrf DIA 0.0.0.0 0.0.0.0 y.y.y.y
ip prefix-list DIA-out seq 5 permit 208.50.120.32/27
ip prefix-list DIA-out seq 10 deny 0.0.0.0/0
access-list 10 deny 208.50.120.32 0.0.0.31
access-list 10 permit any
Regards Andrew
Andrew
router bgp 64610
no synchronization
redistribute static
no auto-summary
Jon
Jon
Many Thanks, I will add th eaddress family and let you know what happens
Regards Andrew
Jon
Many thanks this has fixed the problem and I now have Internet connectivity.
Regards Andrew
Andrew
No problem, glad to have helped.
Jon
The usual setup for BGP in your scenario is a BGP session from the global routing table and another session from within the VRF. That would change your BGP config to:
router bgp 64610
no synchronization
redistribute static
no auto-summary
neighbor y.y.y.y remote-as 3549 ! Internet peering
no auto-summary
redistribute static
exit-address-family
The assumption is that "y.y.y.y" is reachable from VRF DIA. In your given example the VRF DIA only has a default route and likely the return traffic is the issue.
Can you check your BGP sessions with "show ip bgp summary" in the current implementation and additionally with "show ip bgp vpnv4 vrf DIA summary" in my example?
In your example it *might* show "idle" wheres it should really show the number of received routes.
A side note: Your prefix list
can either be simplified to:
because there is an implicit deny at the end, or you might want to consider using
ip prefix-list DIA-out seq 10 deny 0.0.0.0/0 le 32
with statement 10 equal to a "deny any" for visibility in the configuration.
The statement ip prefix-list DIA-out seq 10 deny 0.0.0.0/0 will only deny the default route.
Hope this helps! Please rate all posts.
Regards, Martin
Martin
I don't think the prefix list and distribute list are needed. I think Andrew had to use them because both peerings were under the global BGP config. By moving the DIA vrf to an address-family and only having the network 208.50.120.32 advertised from there i think they can safely be removed.
Jon
Hi Jon,
hm. ... Yes and No. Technically speaking if all informations given above apply, you are right. BUT, first, this is BGP to the internet and you should have filters in place. In fact I would recommend an outbound AS path list as well preventing any update with a non-empty path.
You may call it paranoia, but I have seen so many unprotected enterprise BGP routers ...
Second, internet access is likely provided to hosts, which will need both, internet and intranet access. So, after the testing stage is over, there will be some connectivity between both worlds. This also means that internal routes need to be in the internet VRF. I was also thinking about that time ...
That are the reasons why I left the filter in place.
Regards, Martin
Martin
Thanks for the information and yes y.y.y.y is reachable from VRF DIA, I will implement your's and Jon's solution and let you know what happens
Regards andrew
Martin
Here is the output of the sh ip bgp... both before and after the changes to add address-family commands.
BGP status before address-family commands added
router# sh ip bgp summ
BGP router identifier y.y.y.y, local AS number 64610
BGP table version is 522671, main routing table version 522671
162 network entries using 19440 bytes of memory
162 path entries using 8424 bytes of memory
10/8 BGP path/bestpath attribute entries using 1240 bytes of memory
5 BGP AS-PATH entries using 120 bytes of memory
1 BGP extended community entries using 24 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
Bitfield cache entries: current 2 (at peak 4) using 60 bytes of memory
BGP using 29308 total bytes of memory
BGP activity 248323/248160 prefixes, 259426/259263 paths, scan interval 60 secs
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
x.x.x.x 4 6745 35376 33843 522671 0 0 1w3d 59
y.y.y.y 4 3549 33236 34513 0 0 0 03:10:47 Idle
BGP status after address-family commands added
12/8 BGP path/bestpath attribute entries using 1488 bytes of memory
6 BGP AS-PATH entries using 144 bytes of memory
BGP using 29580 total bytes of memory
BGP activity 248324/248160 prefixes, 259427/259263 paths, scan interval 60 secs
x.x.x.x 4 6745 35389 33856 522671 0 0 1w3d 59
y.y.y.y 4 3549 33236 34513 0 0 0 03:17:00 Idle
router# sh ip bgp vpnv4 vrf DIA
BGP table version is 8, local router ID is y.y.y.y
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
Route Distinguisher: 3549:2 (default for vrf DIA)
r> 0.0.0.0 207.138.94.181 0 64875 3549 i
*> 208.50.120.32/27 0.0.0.0 0 32768 i
router#show ip bgp vpnv4 vrf DIA summ
BGP table version is 8, main routing table version 8
2 network entries using 280 bytes of memory
2 path entries using 136 bytes of memory
12/2 BGP path/bestpath attribute entries using 1488 bytes of memory
BGP using 2132 total bytes of memory
BGP activity 248324/248160 prefixes, 259427/259263 paths, scan interval 15 secs
207.138.94.181 4 3549 233 136 8 0 0 00:05:44 1
Regards Andrew
Martin
Regards Andrew
