04-16-2008 03:11 AM - edited 03-15-2019 10:05 AM
Hi Guys,
I need to expand the 9 digits the carrier is presenting to 12 digits to match my DN`s.
I have tried using a translation pattern to prefix the extra 3 digits but its not working.I have not got my head round the dial-peer thingy so will appreciate any help or sample config i can look at...
I have twelve digit extension/DN numbers but for incoming calls the carrier is presenting only the last nine digits.
04-16-2008 04:04 AM
For example you can do it setting "Prefix DN" (Call Routing Information - Inbound Calls) in you ccm's gateway configuration.
If you have h323 gateway you can also do it via voice translation-rule on router or translation pattern on CCM (gw should point only to tris TP via separate partition, TP should have CSS with your DNs partition; you can translate/prefix there calling and called party numbers).
regards,
PK
04-16-2008 04:05 AM
try this
voice translation-rule 1
rule 1 // /XXX/ where x equals the digits you want to add
voice translation-profile pstn
translate called 1
dial-peer voice X pots
translation-profile incoming pstn
where X is the number of your existing inbound dial-peer
add these commands and you should be ok.
cheers
mark
04-16-2008 06:08 AM
Hi there,
At the moment i have:
rule 1 // /390/
voice translation-profile PSTN
translate called 1
dial-peer voice 50 voip
destination-pattern XXXXXXX.. ( digits presented by telco)
session target ipv4:X.X.X.X
incoming called-number .T
dial-peer voice 30 pots
incoming called-number XXXXXXX..
direct-inward-dial
port 0/0/0
forward-digits all
dial-peer voice 51 voip
destination-pattern XX..
dial-peer voice 31 pots
direct-inward-dial
port 0/0/1
forward-digits all
dial-peer voice 32 pots
direct-inward-dial
port 0/1/0
forward-digits all
dial-peer voice 33 pots
direct-inward-dial
port 0/1/1
forward-digits all
I forgot to mention i have 3 bri circuits for incoming/outgoing calls and gateway is h323.
04-16-2008 06:19 AM
try:
rule 1 /\(.*\)/ /390\1/
04-16-2008 06:20 AM
I do not see you actually applying the translation profile to your dial-peers. Try adding "translation-profile incoming PSTN" to each of your pots dial-peers. Your voip dial-peers will also need to be updated to reflect a destination-pattern that includes the 390 at the beginning.
04-16-2008 06:31 AM
Hi ,
You can also test the result with the command :
router# test voice translation-rule 1 123456
It will show you the following result:
Matched with rule 1
Original number: 123456 Translated number: 390123456
Original number type: none Translated number type: none
Original number plan: none Translated number plan: none
After that you must apply this translation to your voice-port or you dial-peer .
So it is up to you to choose :
translation-profile outgoing PSTN
or
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/1/0
voice-port 0/1/1
There is 1 port too much .
Olivier
04-16-2008 07:10 AM
Ok,
Tried adding to pots and voice ports still not happening.I have a DN on CCM 390abcdefghi
and no translation patterns as 390abcdefghi is what the gateway should be passing to the ccm.I am back to my base config now as the previous posts are conflicting information.Please help :
#test voice translation-rule 1 abcdefghi
Matched with rule 1
Original number: XXXXXXXXX Translated number: 390abcdefghi
voice-port 0/0/0
no non-linear
compand-type a-law
cptone XX
voice-port 0/0/1
compand-type a-law
cptone XX
voice-port 0/1/1
compand-type a-law
cptone XX
destination-pattern 390abcdefg..
destination-pattern .T
incoming called-number abcdefg..
direct-inward-dial
port 0/0/0
forward-digits all
direct-inward-dial
port 0/0/1
forward-digits all
direct-inward-dial
port 0/1/1
forward-digits all
04-16-2008 09:32 AM
You might want to take a look at this link:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
Also it will be very helpful if you post whole config file with controllers, Interfaces etc as well let us know the hardware (F.i. 3745,etc)
Try this:
rule 1 /.*\(....$\)/ /390\1/
voice translation-profile 1
translate called 1
voice-port 1/0:15
translation-profile incoming 1
translate called 1
input gain -3
output attenuation 3
echo-cancel coverage 32
no vad
cptone XX
bearer-cap Speech
I believe the voice ports bellow are analog for Faxes:
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/1/1
#sh inventory or sh diag it will tell you if you have FXS WIC ports.
add the following :
voice call send-alert
voice rtp send-recv
voice service voip
fax protocol pass-through g711ulaw
h323
h225 timeout tcp call-idle value 0
no h225 timeout keepalive
modem passthrough nse codec g711ulaw
voice class codec 1
codec preference 1 g711ulaw
codec preference 3 g729r8 bytes 40
voice class h323 1
h225 timeout tcp establish 2
h225 timeout setup 3
preference 1
destination-pattern 390[1-9]...
progress_ind setup enable 3
voice-class codec 1
voice-class h323 1
session target ipv4:x.x.x.x
dtmf-relay h245-signal
no vad
preference 2
voice-class codec 1
voice-class h323 1
session target ipv4:x.x.x.Y
no vad
Hope this helps.
Maddox
04-17-2008 12:22 AM
Hi there,
Thanks for replying.I have already the voice call send-alert and voice rtp etc.As mentioned above i am using 3 bri circuits for incoming/outgoing calls so thats what those voice ports are for.Outgoing works fine and i am using G729 instead of G711.
How can i check on CCM 5.1 that calls are actually coming in because i can see my dial-peers being matched etc so would like to be able to see whats being sent to the CCM from the gateway and to be able to see on the CCM whats being received from the gateway.
04-17-2008 12:57 AM
Hi again ,
Have you tried with the translation outgoing in the voice-port ?
Incoming will not work because you must send out the translation result from the pots leg to the voip leg . So It is not to apply in an incoming mode .
Can you send the result of a debug voip ccapi inout of a call pointing to an extension of your CCM and to see what is sended to your ccm ?
Olivier
04-17-2008 01:53 AM
Yes i have applied the translation profile outgoing on my voice ports but it still wont work.Perhaps its something to do with the pots dial-peer only sending the wildcards by default not sure.
abcdefghi = 9 digits presented by telco
390abcdefghi = 12 digit extension on ccm
Thanks again !!
04-17-2008 02:43 AM
Hi Guys,
I managed to get it working using a translation pattern so thanks for your help.
