IOS webvpn multiple anyconnect web deployment
Apr 16th, 2008
I have a cisco 2851 router with Cisco IOS Software, 2800 Software (C2800NM-ADVSECURITYK9-M), Version 12.4(11)XW2
I have configured an ssl vpn using the webvpn commands from the cli. Everything works great my problem is I need to support Windows XP, OSX 10.4 on Intel Macs, and OSX 10.4 on PowerPC Macs. I can only issue webvpn install svc flash:/webvpn/svc.pkg
I need to be able to have the webvpn on the IOS router support 3 packages:
anyconnect-macosx-i386-2.2.0128-k9.pkg
anyconnect-macosx-powerpc-2.2.0128-k9.pkg
anyconnect-win-2.2.0128-k9.pkg
I know with the ASA it is possible but how do I support multiple web deployment packages using IOS webvpn?
Thank You.
adns_jeremy Thu, 05/15/2008 - 13:29
Does anyone know if this is possible or how to do this?? I am having the same issue.
erikpotteiger Thu, 06/05/2008 - 08:17
I don't think it is on the Cisco IOS for a router. I purchased an ASA5505 and I can support PowerPC Macs, Intel Macs, and Windows PCs.
