2960 with SNMS 1.5
Apr 16th, 2008
  • Bronze, 100 points or more
  • Participante em Destaque,
    Escolha da Audiência, Maio de 2015
I have 2 catalyst 2960-24TT-L with c2960-lanbase-mz.122-25.SEE2 IOS.
I've installed CiscoWorks SNMS 1.5, but it doesn't find this device as a Cisco device.
what is the problem??
The other devices (WS-C3550-48-EMI, WS-C2950-24) works fine.
Joe Clarke Wed, 04/16/2008 - 08:20
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The 2960s are not supported by SNMS 1.5. We have stopped producing device updates for that release as the product is end of life.
Joe Clarke Wed, 04/16/2008 - 08:24
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Actually, for the 2960s you may be in luck (depending on the sysObjectID). A patch was released about two years ago to address these devices as well as AP1200s for RME 3.5. You will need to install RME 3.5 IDU 13.0, then you can contact the TAC to get the patch for CSCse25066.
The 2960s covered by this patch are:
2960-24TT - 1.3.6.1.4.1.9.1.716
2960-48TT - 1.3.6.1.4.1.9.1.717
2960-24TC - 1.3.6.1.4.1.9.1.694
2960-48TC - 1.3.6.1.4.1.9.1.695
2960-G24TC 1.3.6.1.4.1.9.1.696
