Edison Ortiz Wed, 04/16/2008 - 06:47
  • Hall of Fame,
    Founding Member
You could do DHCP Snooping, see the documentation on the 2960 (your typical L2 switch)
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_40_se/configuration/guide/swdhcp82.html
I couldn't find any information regarding ip source guard so I assume it's not supported
HTH,
__
Edison.
pushpak.lele Wed, 04/16/2008 - 08:29
Can we do IP based control on L2 switch.
Like only particular IP address will be connected to particular switch port
Vaishali
Edison Ortiz Wed, 04/16/2008 - 08:35
  • Hall of Fame,
    Founding Member
IP Based Control ? Do you mean ACLs ?
Well, good question. The documentation states that it can be done
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_40_se/configuration/guide/swacl.html
However, I haven't had the pleasure to do L3 ACLs in L2 switches, so please test away and good luck :)
HTH,
__
Edison.
