Cannot re-install subscriber after upgrade from 3.3(3) to 3.3(5)
Answered Question
Apr 16th, 2008
Dear All,
The CM cluster was upgraded from 3.3(3) to 3.3(5) via maintenance upgrade. And we suspect the subscriber server is out of order and wants to re-install the subscriber server once.
But we do not have the CM3.3(5)installation disk. We only have 3.3(3) disk.
How can we solve this issue?
Any input will be much appreciated!!
Michael.
Correct Answer by Rob Huffman about 9 years 1 week ago
Hi Michael,
You can take the Subscriber and rebuild it as CCM 3.3(3) then perform the 3.3(5) upgrade using the same files you used during the Maintenance upgrade. Make sure to install all SR's etc so the versions match exactly.
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Wed, 04/16/2008 - 06:45
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Michael,
Hope this helps!
Rob
lwai Wed, 04/16/2008 - 06:57
Hi Rob,
Thanks for your information! I will install the subscriber with 3.3(3) installation disk frist and upgrade it via maintenance patch to 3.3(5) as before.
Many thanks! You solve my issue immediately!
Michael.
Rob Huffman Wed, 04/16/2008 - 07:31
  • Hall of Fame,
    Founding Member
Hi Michael,
You are very welcome :) Let us know if any issues arise.
Take care,
Rob
