ExtensionMobility @ CUCM6, weird responses
Answered Question
Apr 16th, 2008
Hi!
Im trying to get info via EM services at address: http://CM:8080/emservice/EMServiceServlet, but it still responses following xml:
<?xml version="1.0"?>
<response>
<failure>
<error code="0">Other Parser Error: Connection refused
</error>
</failure>
</response>
to form in html, see attachement. When Im trying to access that service address via browser, it shows HTTP Status 500, NullPointer Exception.
Does included form work for you, please? Where can be problem?
Thanks in advance!
Correct Answer by agiaccone about 8 years 9 months ago
I've tried your emquery.html on my CUCM 6.1 box and worked fine. I used an EM proxy user credentials and my userid.
As for the NullPointer exception, it's a normal behavior, the EM applet expects at least one argument (the device) so if you point simply to
http://CM:8080/emservice/EMServiceServlet it finds no argument i.e. a Null argument.
To test the service point to http://CM:8080/emservice/EMServiceServlet?DEVICE=SEPXXXXXXXX
Alberto
Overall Rating: 5 (1 ratings)
stephan.steiner Thu, 04/17/2008 - 05:12
You're posting to port 8080 which should be okay - then again I only know for sure for CCM 5.x. Have you tried other ports (80, 443, 8443)? I know the error 0 very well.. when I had it I sent my EM requests to a ccm5 on port 80 Once I switched to 8080, it worked but it could well be that they changed ports yet again.
Correct Answer
agiaccone Thu, 04/17/2008 - 13:15
Alberto
venca.balak Fri, 04/18/2008 - 00:11
Hi all!
Many thanks to your tests and so...but it works now :-). A problem was that when i send ... i need to 'assign' all this to 'xml variable' like this: xml=... and all this send to EMService. So, my program works now, but attached html form still not :-). But it doesnt matter.Thanks again!!
