fiber duplex
Apr 16th, 2008
Hi all, is it possible to run half duplex over fiber, or can you only run full duplex ?
s.marino Wed, 04/16/2008 - 10:51
Fiber connectivity is at Full Duplex only.
Hope this answered your question.
sdrossen2 Wed, 04/16/2008 - 11:05
What are you wanting to accomplish with running fiber at half duplex? The answer as Sal said is no but there has to be a reason why you want to do this.
ciscograyaw Fri, 04/18/2008 - 10:21
If you're asking 'can you run fiber using only one strand instead of two' then the answer is yes - with BX SFPs you can use only a single strand, at two different wavelengths.
With fiber, you have either 2 distinct fibers (normal runs) or 1 fiber at 2 wavelengths (BX interfaces), so there's always a dedicated send and receive line - there's no need for half-duplex.
