Is there a way to email the supervisors the generated CRS historical report
Apr 16th, 2008
Is there a way to email the supervisors the generated CRS historical reports?
UCCX Enhanced 5.X
Mohan
Abdulbaseer Mohammed Wed, 04/16/2008 - 21:40
  • Silver, 250 points or more
Mohan,
you can save all the reports as .csv or excell format and you can obviously email that.
Please let us know if we don't understand your question.
thanks,
Baseer.
Eric Krieger Thu, 04/17/2008 - 05:18
As fas as I know the CRS Historical Report Client can Print or Export (save) report-files using the integrated schedular.
The only way I can think of to email the reports to the supervisor is to Export the report to a file and email that file.
You probably can automate this using custom scripts and/or tools (check a directory for new files and perform an action, like email them). Maybe someone else knows about such a solution/workaround.
Eric
mp5766_2 Fri, 04/18/2008 - 09:15
Thank you both (Baseer and Eric).
Well, that was the option I was considering Eric. Just wanted to know whether there was an option to configure for the Historical Reporting Client to email the reports, rather than using windows options. I did look at the Historical Reporting Client configuration extensively and could not find anything and was wondering whether I missed something?
Would it make any difference if we had Premium License (I know what the Premium license provides with respect to the subsystems etc.., not sure about this particular “feature” I am looking for? Or is this something UCCX does not do at all? We are replacing an Avaya Contact Centre and apparently this is something Avaya can do.
Thanks again for you input.
Mohan
Eric Krieger Fri, 04/18/2008 - 12:54
Mohan,
Changing to Premium doesn't make any difference regarding this wanted "feature". UCCX doesn't have it at all.
Eric
Jonathan Schulenberg Sat, 04/19/2008 - 12:16
  • Cisco Designated VIP,
    2017 IP Telephony
The SQL databases schema is published by Cisco however so you could connect another reporting engine of your choice to them, such as Crystal.
