Migrating to Unified communications exchange 2007
Apr 16th, 2008
we are currently using unity 5.0 and it is in its own active directory domain and forest as well as the exchange 2003..we want to move to exchange 2007 unified communications and this is in a different domain/forest as well...what would be the proper steps to migrate over in a situation like this from untiy 5.0 in one seperate forest than exchange 2007 thats in another forest?
Overall Rating: 4 (1 ratings)
Jaime Valencia Sun, 04/20/2008 - 20:12
you would need to do a DIRT backup and then reinstall the server on the new domain forest to integrate it with Exchange 2007
if this helps, please rate
MauricioB Sun, 04/20/2008 - 20:18
when you say server you mean uninstall the unity server form the old doman reinstall to the new domain right? then re-import everything?
whats the process to intgrate with exchange 2007?
Jaime Valencia Mon, 04/21/2008 - 03:27
yes, re-install from scratch and restore is the process, all the info is here:
Renaming a Cisco Unity 5.x Server or Moving a Cisco Unity 5.x Server to Another Domain
Changing the Partner Exchange Server
