Crypto Maps and Access Rule
Answered Question
Apr 16th, 2008
When I create a crypto map, do I still need to create an access list rule for it? Or anything on the cryptomap will be enrypted and I don't need to create an access rule?
Correct Answer by cisco24x7 about 8 years 11 months ago
if you have "sysopt connection permit-ipsec" in the configuration, IPSec traffics will bypass
the access rule ACL you applied to the
interface.
The work around is to disable with "no sysopt
connection permit-ipsec" and let the ACL do
the work for you.
Overall Rating: 4 (1 ratings)
Jon Marshall Wed, 04/16/2008 - 23:45
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Could you clarify what you mean. Without an access-list the crypto map doesn't know what traffic to encrypt.
Jon
bauti1428 Thu, 04/17/2008 - 05:55
On the ASA when you create a site to site, you create a crypto map and you setup what traffic to encrypt it looks like an access rule. What I noticed was that I'm seeing it from the access rule that it was being blocked but the enrypted traffic seems to be still working. I opened up certain ports to allow on one of our site to site and I configured that in the crypto map rule.
Correct Answer
cisco24x7 Thu, 04/17/2008 - 06:15
  • Silver, 250 points or more
interface.
the work for you.
bauti1428 Thu, 04/17/2008 - 06:24
How do I find out if sysopt connection permit-ipsec is enable or not? Also in our ASA I don't have permit-ipsec on permit-vpn unless they are the same.
