Vg224 that will not turn on led for an analog phone
Apr 16th, 2008
I have a AAstra 9110 analog phone connected to a vg248. When a message is left in the unity voicemail the mwi led will not activate on the analog phone. What are the correct settings in the VG to activate the led on the analog phone?
Overall Rating: 4 (1 ratings)
a.baird Wed, 04/16/2008 - 11:13
Hi Tristan.
You may be hitting this caveat:
CSCdu79519
Voltage might be too low for Message Waiting Indication (MWI) lamps on some phones.
Some older phones that use MWI lamps might not light up, even if the VG248 port is configured to indicate Message Waiting with the Lamp setting. To check this setting, go to the following path from the Main screen:
Telephony > Port specific parameters > MWI type
This problem arises because MWI lamps require a line voltage greater than the maximum voltage that the VG248 can supply.
If you suspect that your lamp MWI should be lit, check the configuration of the port and the status of the messages in your mailbox. If the configuration is correct and you have a waiting message, you should try replacing the phone with one of a similar type to confirm that your phone is not faulty. If the lamp still does not light, you probably have a phone that cannot have its MWI lamp lit by the VG248. Other phone functionality is not impaired by the lamp deficiency.
The only workaround to this problem is to consider replacing your phone. Test the new phone before committing to a large purchase.
-Adam
tdflowers Thu, 04/17/2008 - 07:14
Adam thanks for the response. I was able to reolve my issue by going to Configure>Telephony>Port Specific Parameters> select the port that the analog phone is connected to (enter)>Change output gain to
-14db. This will change the output on the port enough to activate the led. Thanks again!
