Inventoring Physical Serial Numbers
Apr 16th, 2008
Retrieving physical serial numbers remotely or physically getting the serial numbers and placing them in Cisco Works for future use. Will the serial numbers be retained in Cisco Works even if switch / router is reconfigured?
Microsoft Windows Server 2003
Standard Edition
Service Pack 2
Intel Xeon CPU 3.00 GHz
2.99 GHz, 2.00 GB Ram
C: 12.77 Operating System
D: 136.48 All Cisco Works programs installed on this drive
Name Version License Size Status
CiscoWorks Common Services 3.1.1 Licensed Not applicable
Campus Manager 5.0.2 Purchased 300
CiscoView 6.1.7 Licensed Not applicable
CiscoWorks Assistant 1.0.1 Licensed Not applicable
Device Fault Manager 3.0.2 Purchased 300
Internetwork Performance Monitor 4.0.1 Purchased 300
Integration Utility 1.7.1 Licensed Not applicable
LMS Portal 1.0.1 Licensed Not applicable
Resource Manager Essentials 4.1.1 Purchased 300
Health and Utilization Monitor 1.0.0 Evaluation 100
Overall Rating: 5 (1 ratings)
Joe Clarke Wed, 04/16/2008 - 13:10
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
As long as the chassis remains the same, the serial number data will be the same. That said, many devices are modular, and each module has its own serial number. If those modules are swapped out, then the new modules will have different serial numbers. RME can collect serial number data automatically from most newer devices. Older devices may require you to manually configure the serial number either within RME, or on the device using the "snmp-server chassis-id" command.
