VPN life time setting help
Apr 16th, 2008
Hi, I have a few VPN's connected to my Cisco Concentrator and ASA. The thing is I have never set the life time on the tunnel on the regional sites configs (877's, 1841's), althought on the ASA and Concentrator I have.
What problem's would this create and should I set this?
e.g. Set security-association lifetime seconds 28800
jbayuka Tue, 04/22/2008 - 12:20
  • Bronze, 100 points or more
If you are not configuring the lifetimes in all the devices but go with default means not a problem. However, if you configure lifetime in any one of the devices and go with default in other, then you will be getting the issues.
