CUCM 6.0.1 high cpu usage
Apr 16th, 2008
I have a new Unified communication manager installation on tha msc 7815-I2 server.I have about 100 users/phone. I have a great problem , random cpu usage of the server go up until 99% and then phone that are not registered cannot register . I have to restart ccm service to came back to normal operation. A lot of my users use extension mobility. And they also cannot connect or disconnect during ccm cpu problem. Phone that are already registere seems work correctly. Anyone have any ideas?
I'm Desperate
ebreniz Tue, 04/22/2008 - 12:25
  • Silver, 250 points or more
What is your exact version of callmanager? I found two bugs I think might be the culprit. CSCsl71487 and CSCsi84173 Please check these two bug. This is only happens on IBM servers that have the SCSI RAID controllers installed and IBM Director 4.20.2 installed which is part of OS 2000.2.7, 2000.4.1 and 2000.4.2 MCS OS versions. Do not use IBM Raid or the complete IBM director software.
marco.mazzoleni... Tue, 04/22/2008 - 23:36
I have Cisco Unified Communication Manager 6.0.1 . This system is linux based and also I have 7816I server that not have raid system. So I think that these bugs do not apply to my situation.
Thank you.
bigcappa1 Mon, 05/05/2008 - 14:29
Marco,
We had this issue also. What 6.0.1 version do you have. We had to get a patch from Cisco do sort this. Did you manage to get it sorted
Paul
cisco.madhab Wed, 05/07/2008 - 19:39
Hii
I have same problem but I am using CCM 5.1. please help me. how to resolve the High CPU Usages?
madhab
bigcappa1 Thu, 05/08/2008 - 00:55
madhab,
Cant find an issue with 5.1 apart from when used with a VG224 but as 5.1 is not the best I would suggest uograding to 6.0 or even 6.1 as soon as possible
cheer
P
cisco.madhab Thu, 05/08/2008 - 01:48
hii.
I am not using any VG224 because I am using non gatekeeper inter clustering.
thanks
Madhab
I've got exactly the same problem.
When we use extension mobility the CPU go to 100%.
The only way to correct it is to restart CCM service...
If a user try to connect to use EM service when the CPU is about 100%, the registration failed.
I am sure that extension mobility service is the problem.
I Upgrade CUCM from 6.0.1.2000 to 6.0.1.3000-7 but it didn't solve this issue.
Somebody have an Idea ?
bigcappa1 Wed, 08/20/2008 - 12:20
Are you able to upgrade to 6.1.1 or 6.1.2, I know the issue was resolved in 6.1.1
Paul
bigcappa1 Thu, 08/21/2008 - 01:23
Benoit,
I think it may be this CSCsj6237, but there are other similar, do a search of the bug tool using high CPU as the keyword.
Paul
