Problems trying to change the 1811 modem's transmission speed
Apr 16th, 2008
Hi all,
We are trying to connect some remote offices through an 1811, the idea is to have an Ethernet WAN and an ISDN backup, we already installed the routers and most of them are working well, but some of them are having problems to make the connection through the modem.
We made some test and we realized that the problem was in the line's quality, so it could transmit but at a really slow speed, we need to change the transmission speed and make it at least 2.4 Kbps, we already tried to change it with some commands like AT commands but it doesn't change.
I will appreciate if someone could tell me how can I change it or if I must change any other parameter before try to change the speed (like compression) and if I need it how can I do it too?.
Thank you
aghaznavi Tue, 04/22/2008 - 12:35
  • Silver, 250 points or more
paste your shoe tech output?
