ip phone 7941 time change issue
Apr 16th, 2008
I know of two ways by which the time on the IP Phone 7941 can be changed.
1. go to call manager os admin and set the time and restart the CCM.
2. create a date/time group, associate it with device pool and associate the ip phone with that device pool.
The first option is last resort. The second option does not work ( I dunno why )
Is there any other way of changing time on the IP Phone 7941 ?
Anonymous (not verified) Wed, 04/23/2008 - 06:14
You can use a ntp server or the windows time service to sync the callmanager time.A default Date/Time Group called CMLocal is configured automatically when you install Cisco CallManager. CMLocal is synchronized to the active date and time of the operating system on the server where Cisco CallManager is installed. After installing Cisco CallManager, you can change the settings for CMLocal as desired. Normally, server date and time should be adjusted to the local time zone date and time.
