WAAS 4.0.17 self-diag and warnings
dkennedy99
After upgrading to 4.0.17, I noticed that there is now a 'test self-diagnostics all' command. After running this on my 612 Edge WAE, I received the following warnings:
Test WARN [tfo]
WARN ASYMMETRIC Asymmetric routing is seen in the device
Action:
Check router's network configuration and WCCP redirection on the router.
and
Test WARN [wafs]
WARN NO_WAFS_CONN No transport connection to configured CIFS WAE peer
10.104.192.3
Action:
CIFS transport tunnel is not established to the device. Please check if WAF
S services are running correctly on that device and/or connectivity is configure
d properly for this device.
We are having a few issues with the initial rollout WAAS and this self-diag confirms some things, but can anyone give me some troubleshooting steps to resolve these warnings?
At the edge, we're running a 3750 and 612 WAE. At the core we're running a 512 CM and 612 core WAEs.
Here's a portion of the 3750 config that contains the WCCP info:
**to WAN**
interface Vlan1
description Backbone Subnet
ip address 10.96.192.14 255.255.255.240
ip wccp 62 redirect in
**to clients**
interface Vlan200
ip address 10.100.8.7 255.255.248.0
ip wccp 61 redirect in
**to WAE **
interface GigabitEthernet1/0/7
switchport access vlan 500
interface Vlan500
description Management Subnet
ip address 10.96.208.254 255.255.255.128
David,
Yes, this is normal. Only the WAFS Core service is listening on tcp/4050.
Can you verify by connecting to the individual device GUIs that the WAFS services are started?
Zach
6 Replies 6
jsivulka
Level 5
Level 5
The issue is seen on the Edge devices, and wrongly prompts on missing transport connection to the Core device.
'test self-diagnostic all' fails to validate wccp settings. . Try this bug CSCsl42759
http://www.cisco.com/en/US/prod/collateral/contnetw/ps5680/ps6870/data_sheet_cisco_wide_area_application_services_WAAS_software_version_4_0.html
http://www.cisco.com/en/US/prod/collateral/contnetw/ps5680/ps6870/prod_white_paper0900aecd806d976a.html
Zach Seils
Level 7
Level 7
David,
There are two warnings in the diagnostic output:
The [tfo] warning is raised when the 'Asymmetric Client' or 'Asymmetric Server' counters in the 'sh stat tfo pass-through' command output are greater than zero. This is an indication that interception is not happening bi-directionally. You should verify that there are no network paths between the client and server with WCCP configured.
The [wafs] warning means that the WAFS Edge service is not able to connect to the WAFS Core service running on 10.104.192.3. You should verify that all of the WAFS services are started, and that there is nothing blocking communication between the devices on TCP port 4050 (the cisco-wafs port).
Zach
Good info. Thanks.
Regarding port 4050 for WAFS. Should I be able to telnet to each peer (edge-to-core and core-to-edge) on this port? If there is an issue on the WAE, how would I go about restarting or starting the dependant service?
I think the tfo warnings were leftover stats when we were configuring. Cleared up now.
David
Regarding WAFS communication, I can get to port 4050 from edge-to-core, but not from core-to-edge. Is this normal?
David,
Zach
I have verified that all is working through the WAE GUIs and the core service is listening on tcp/4050 now.
Thanks for your help, Zach!
David
