PIX 506E VPN caan connect, but no LAN
Answered Question
Apr 17th, 2008
Heelo, We have a 506E with 6.3(3). we want to use Cisco VPN clinet to connect and can do so, but cannot ping on the LAN or connect to the servers...Need help wih the configurations as we are novices perhaps..Can someone look at the attached config. and see if we overlooked something...Thanks
Correct Answer by acomiskey about 8 years 10 months ago
Change your pool to something outside of 192.168.2.0/24.
ip local pool vpnpool 192.168.x.60-192.168.x.63
Then add a nat exemption acl for this network.
access-list nonat permit ip 192.168.2.0 255.255.255.0 192.168.x.0 255.255.255.0
nat (inside) 0 access-list nonat
Then, also change your split tunnel acl to reflect the new pool
access-list SplitTunnel permit ip 192.168.2.0 255.255.255.0 192.168.x.0 255.255.255.0
Overall Rating: 5 (1 ratings)
Correct Answer
acomiskey Thu, 04/17/2008 - 06:03
