Need Information about More ports Fiber Optic Switches
Apr 17th, 2008
Hiii Guys,
I need information about which Cisco Switch consist more Fiber Optic Ports. I knew one model Cisco (WS-C3750G-12S-E) Catalyst 3750G-12S-12 Gigabit Ethernet SFP ports. But we can using this we can make stacking up to 9 devices. Even though I need more than 12 ports in single device. Could any one help me out in this.
mohammedmahmoud Thu, 04/17/2008 - 00:55
Hi Sayed,
Please take a look at the 3560E-12SD:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps7078/product_data_sheet0900aecd805bac22.html
[edit] Sorry, didn't catch from the first post reading that you've considered stacking (the 3560 doesn't support stacking).
For more than 12 fiber ports on a single device you'll need to go for the 4500 series with the appropriate modules:
http://www.cisco.com/en/US/products/hw/switches/ps4324/prod_models_comparison.html
Cisco Catalyst 4500 and 4500-E Series Line Cards
http://www.cisco.com/en/US/prod/collateral/modules/ps2710/ps5494/product_data_sheet0900aecd802109ea.html
WS-X4418-GB Cisco Catalyst 4500 Gigabit Ethernet Module, server switching 18 ports (GBIC).
BR,
Mohammed Mahmoud.
mohammedmahmoud Thu, 04/17/2008 - 01:36
Also check this module:
WS-X4448-GB-SFP Cisco Catalyst 4500 Gigabit Ethernet Module, 48-ports 1000X (SFP)
But please do note that all these modules oversubscribe the ports, please check the specs of each.
BR,
Mohammed Mahmoud.
Joseph W. Doherty Thu, 04/17/2008 - 02:22
You should be able to stack up to 9 3750s of any model. (Although you can bump into issues if you mix feature sets, e.g. the difference your WS-C3750G-12S-E and WS-C3750G-12S-S, or between IOS versions.) You can also mix the 3750 and 3750-E series within the same stack. (With discontination of the 3750G-16TD, only method to get 10 gig to the stack.)
If you need more than 108 fiber gig ports in a single 3750 (stack) "device", you'll need to consider the chassis solutions. For instance, the 6500's WS-X6748-SFP provides 48 ports or up to 384 fiber gig ports for a 6509.
