MM_NO_state
Apr 17th, 2008
I've set up a vpn tunnel ,when i enter the sh crypto isakmp sa command i get the message:
dst src
"peer IP" "my IP" state conn-id slot
MM_KEY_EXCH 2 0
and later i get this message
dst src
MM_NO_state 2 0
the policy requirements are:
from the other peer side, they have a concentrator 3015,
Authentication
ESP/MD5/HMAC-128
Encryption
3DES-168
from my side i have a cisco router 805
and this is the policy that i have done:
Protection suite of priority 20
encryption algorithm:Three key triple DES
hash algorithm:Secure Hash Standard
authentication method: Pre-Shared Key
Diffie-Hellman group: #2 (1024 bit)
lifetime:86400 seconds, no volume limit
any solution please?
smahbub Wed, 04/23/2008 - 06:17
  • Silver, 250 points or more
MM_KEY_EXCH and MM_NO_STATE are some of the states that may be displayed in the output of the show crypto isakmp sa command.
Meaning of the states you have mentioned:
1)MM_KEY_EXCH::
This message says that the peers have exchanged Diffie-Hellman public keys and have generated a shared secret. The ISAKMP SA remains unauthenticated.
2)MM_NO_STATE::
This message says that the ISAKMP SA has been created, but nothing else has happened yet. It is "larval" at this stage(there is no state at present).
For more info about the "show crypto isakmp sa command" refer the URL below:
http://www.cisco.com/en/US/docs/ios/12_3/security/command/reference/sec_r1g.html#wp107407
