ASA 5505 Ping DMZ
Apr 17th, 2008
I have a problem, i can't go to the DMZ when I try pinging of the lan to the dmz and vice versa.
ASA Version 7.2(3)
hostname ciscoasa
domain-name default.domain.invalid
enable password xxx
names
interface Vlan1
nameif inside
security-level 100
ip address 10.1.0.2 255.255.0.0
interface Vlan2
nameif outside
security-level 0
ip address 10.7.0.1 255.255.0.0
interface Vlan3
no forward interface Vlan1
nameif dmz
security-level 100
ip address 10.6.0.1 255.255.0.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
switchport access vlan 3
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd xxx
ftp mode passive
dns server-group DefaultDNS
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu dmz 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-523.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
static (outside,inside) 10.1.0.0 10.7.0.0 netmask 255.255.0.0
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 10.1.0.0 255.255.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:xxx
: end
Overall Rating: 5 (1 ratings)
acomiskey Thu, 04/17/2008 - 05:13
static (inside,dmz) 10.1.0.0 10.1.0.0 netmask 255.255.0.0
access-list dmz extended permit icmp 10.6.0.0 255.255.0.0 10.1.0.0 255.255.0.0
access-list dmz extended deny ip 10.6.0.0 255.255.0.0 10.1.0.0 255.255.0.0
access-list dmz extended permit ip any any
access-group dmz in interface dmz
