ASA 5505 Stop traffic LAN
46140258G
When i connect to existing LAN the ASA 5505, Stop trafic servers.
Why , what is missconfigured.
ASA Version 7.2(3)
hostname ciscoasa
domain-name default.domain.invalid
enable password xxx
names
interface Vlan1
nameif inside
security-level 100
ip address 10.1.0.2 255.255.0.0
interface Vlan2
nameif outside
security-level 0
ip address 10.7.0.1 255.255.0.0
interface Vlan3
no forward interface Vlan1
nameif dmz
security-level 100
ip address 10.6.0.1 255.255.0.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
switchport access vlan 3
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd xxx
ftp mode passive
dns server-group DefaultDNS
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu dmz 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-523.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
static (outside,inside) 10.1.0.0 10.7.0.0 netmask 255.255.0.0
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 10.1.0.0 255.255.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:xxx
: end
acomiskey
Level 10
Level 10
Add a default route...
route outside 0.0.0.0 0.0.0.0
Hi Acomiskey,
Hope fine.
I am having a problem in my Pix FW to block a particular network to go to the internet. Here is the scenerio.
My FW has 3 interfaces: Outside(Sce 0), Inside (Sec100) and DMZ(Sce50). Whole inside block (let say 10.x.x.x) is being NATed (Here using DynamicNAT/PAT) to the Outside Interface while going towards Internet. NAT 0 is using between Inside and DMZ Servers to communicate. Here is the configuration.
nat-control
global (Outside) 1 interface
nat (Inside) 1 access-list nat
access-list Nat_ACL extended permit ip 10.0.0.0 255.0.0.0 any log
Now what the problem is - I want to block a specific network 10.10.10.0/24 to go to the the Internet. I tried to change the Nat_ACL ACL here by denying the 10.10.10.0/24 to any and then allow/permit 10.x.x.x to any. But it didn't work.
Any suggestion or ideas or any other way how can I block this 10.10.10.0/24 to go to the Internet. Ur help would be highly appreciable.
Adnan
tyagi.v
I don't see any nat & acces list for DMZ traffic, also again check your static command.
Hi Adnan,
All you have to do is assigning an ACL (Not NAT Acl) to inside interface as following
access-list inside_access_in deny tcp 10.10.10.0 255.255.255.0 0.0.0.0 0.0.0.0 eq www
access-list inside_access_in permit ip any any
access-group inside_access_in in interface inside
