Cannot get GLC-T/SFP-GE-T to work with SPA-2X1GE in 12.2(33)SR
Apr 17th, 2008
Does any 7600 user able to get GLC-T or SFP-GE-T working with SPA-2X1GE under 12.2(33)SR IOS? I am having trouble to get it work after upgrade from 12.2(18)SX to 12.2(33)SR series. Both GE port and GLC-T/SFP-GE-T are working when I am using 12.2(18)SXF4. I have tried 12.2(33)SRC and 12.2(33)SRB2, and combination of GLC-T and SFP-GE-T adapter, the GE ports keep down with the two 12.2(33) version.
C7604#show mod
Mod Ports Card Type Model Serial No.
1 2 Supervisor Engine 720 (Active) WS-SUP720-3BXL SAD0905XXXX
4 0 4-subslot SPA Interface Processor-400 7600-SIP-400 JAB0935XXXX
Mod MAC addresses Hw Fw Sw Status
1 0017.9441.c100 to 0017.9441.c103 5.2 8.4(2) 12.2(33)SRC Ok
4 0012.da9b.55f8 to 0012.da9b.5677 2.1 12.2(33)SRC 12.2(33)SRC Ok
Mod Sub-Module Model Serial Hw Status
1 Policy Feature Card 3 WS-F6K-PFC3BXL SAL1038XXXX 1.8 Ok
1 MSFC3 Daughterboard WS-SUP720 SAL1037XXXX 2.5 Ok
4/0 2xOC3 POS SPA SPA-2XOC3-POS JAE1133XXXX 1.0 Ok
4/1 2xGE SPA SPA-2X1GE JAB0849XXXX 2.2 Ok
Mod Online Diag Status
1 Pass
4 Pass
4/0 Pass
4/1 Pass
C7604#show run int g4/1/1
Building configuration...
Current configuration : 157 bytes
interface GigabitEthernet4/1/1
ip address
ip flow ingress
load-interval 30
no negotiation auto
It may have something to do with the negotiation. But I can't turn it on in 12.2(33).
C7604(config)#int g4/1/1
C7604(config-if)#negotiation auto
The "[no] negotiation auto" command will have no effect with this interface
Any suggestion is welcome. Thanks.
Best regards,
Calvin Chu
irisrios Wed, 04/23/2008 - 06:19
The new 7600-specific 12.2(33)SR versions don't support all features, but they could be seen as "more recent" than 12.2(18)SX, and the section is about the minimum requirements. 12.2(33)SRB on C7600 cannot set the data-port into trunk mode for inline inspection.
calvin.chu Wed, 04/23/2008 - 18:23
Thanks for the information. Actually we want to test out the new VPLS Autodiscovery, BGP-based feature which currently only available in 12.2(33)SRC and 12.2(33)SRB2. 12.2(33)SRC should support the hardware I am using if the page correct:
I also tested with GLC-SX-MM and it is working fine. Still wondering it is hardware issue or software bug.
