ACS v2.4 to 4.1
Apr 17th, 2008
I have ACS 2.4 Running on Windows NT.
Building a New server Running 2003. Installing ACS 4.1.
How do I get the Configuration off the old server onto the New ACS install (user Settings,Groups and NAS).
Dave
Overall Rating: 5 (1 ratings)
Jagdeep Gambhir Thu, 04/17/2008 - 06:35
  • Red, 2250 points or more
Dave,
Quite lengthy process , These are steps to upgrade the ACS 2.4.1.
1)Make sure Windows NT is with SP6a
2)Upgrade to ACS 2.6.4
3)Now take a backup from the ACS 2.6.4
4)Build a Windows 2000 server with SP2 and install ACS 2.6.4
5)Restore the backup take you took on step 3 to the newlybuilt server
6)Now upgrade ACS to 3.0.4 and install SP4 on the Windows 2kserver
7)Upgrade ACS3.0.4 to ACS3.3.1
8)Now take a backup and rstore this backup on the ACS3.3.1installed on Windows 2003 Server.
Incase you don't have NT then you can try it with 2000 0r 2003 as I was able to upgrade it sometime back.
~JG
Do rate helpful posts
dmccumiskey Thu, 04/17/2008 - 23:49
Thanks for the Reply, very Helpfull, but a Lot of Work :(
IS there anyway to get a List of Configured NAS's on the ACS server.
Dave
