Call Admission Control Log Files?
Apr 17th, 2008
Hi Guys,
I have location based CAC configured on our cluster of CCM's (4.1)and is used for small multiple remote sites dialling internally, these sites are restricted to a specific number per site depending on their Circuit size, all remote sites using g729.
However I was wondering if an internal on-net call is placed from a remote site and didn't actually suceed due to CAC, is there any log files that I could view this in?
Thanks in advance
Paul
Jaime Valencia Thu, 04/17/2008 - 07:38
  • Cisco Employee,
  • Hall of Fame,
    2011
unfortunately there are no CAC logs on which you can see that information.
the only place where that info shows up is in the CUCM traces
javalenc
if this helps, please rate
gogasca Thu, 04/17/2008 - 09:45
  • Green, 3000 points or more
Apart from CCM traces you need to enable Location traces under CallManager Service Parameters
smithsera1 Thu, 04/17/2008 - 12:20
cheers guys, tks alot for the info, i'll enable the traces and then check them out...
Tks for the help
Paul
