Disable account caching
Apr 17th, 2008
Does anyone know how to disable username caching in ACS 4.1?
We have a problem with password changes initiated from Active Directory.
When we clear the dynamic users after the password change all works well, but we do not want to 'build' the dynamic user table whatshowever.
Thnx!
aghaznavi Wed, 04/23/2008 - 08:01
  • Silver, 250 points or more
ACS can only use one database per username.I think it's a fundamental design issue with ACS, and you can't disable username caching. Better way is clear dynamic user table.
koksm Wed, 04/23/2008 - 22:31
Yes, that is what we do now, but this is nog workable. Every time a user changes his password, he is kicked out by 802.1x because ACS keeps on using the old account to re-authenticate against AD.
