04-17-2008 05:20 AM - edited 03-05-2019 10:26 PM
hi all, i have created the attached diagram in a lab and all is working fine, i can ping all networks (all loopbacks from each router) however there is a small quetion i would like some help. when i ping from any router e.g if i ping from R5 ro lo3 on R3 i only get 40% success rate and same if i ping the other way. In fact i hardly get 100% success when pinging across the cloud. any ideas??
Thanks in advance
04-17-2008 06:05 AM
Please post a traceroute from R5 to R3 and from R3 to R5.
Also post the show ip route from each router toward the destination IP.
__
Edison.
04-17-2008 06:17 AM
Edison here it is
R5#traceroute 3.3.3.3
Type escape sequence to abort
Tracing the route to 3.3.3.3
1 192.168.4.1 892 msec 180
2 172.16.8.3 156 msec * *
Gateway of last resort is not set
1.0.0.0/30 is subnetted, 1 subnets
R 1.1.1.0 [120/4] via 192.168.4.1, 00:00:21, FastEthernet0/0
2.0.0.0/32 is subnetted, 1 subnets
R 2.2.2.2 [120/4] via 192.168.4.1, 00:00:21, FastEthernet0/0
3.0.0.0/32 is subnetted, 1 subnets
R 3.3.3.3 [120/4] via 192.168.4.1, 00:00:21, FastEthernet0/0
5.0.0.0/24 is subnetted, 1 subnets
C 5.5.5.0 is directly connected, Loopback0
6.0.0.0/24 is subnetted, 1 subnets
C 6.6.6.0 is directly connected, Loopback1
172.16.0.0/16 is variably subnetted, 5 subnets, 3 masks
R 172.16.9.252/30 [120/4] via 192.168.4.1, 00:00:21, FastEthernet0/0
R 172.16.8.0/24 [120/4] via 192.168.4.1, 00:00:21, FastEthernet0/0
R 172.16.10.0/24 [120/4] via 192.168.4.1, 00:00:23, FastEthernet0/0
R 172.16.8.2/32 [120/4] via 192.168.4.1, 00:00:23, FastEthernet0/0
R 172.16.8.3/32 [120/4] via 192.168.4.1, 00:00:24, FastEthernet0/0
7.0.0.0/24 is subnetted, 1 subnets
C 7.7.7.0 is directly connected, Loopback2
192.168.4.0/30 is subnetted, 1 subnets
C 192.168.4.0 is directly connected, FastEthernet0/0
R5#
R3#traceroute 5.5.5.5
Tracing the route to 5.5.5.5
1 172.16.9.253 672 msec 1068 msec 80 msec
2 192.168.4.2 912 msec 2284 msec 2140 msec
R3#
R3#ping 5.5.5.5
Sending 5, 100-byte ICMP Echos to 5.5.5.5, timeout is 2 seconds:
Success rate is 20 percent (1/5), round-trip min/avg/max = 336/336/336 ms
R3#
1.0.0.0/32 is subnetted, 1 subnets
O 1.1.1.1 [110/1563] via 172.16.8.1, 00:41:22, Serial1/0
O 2.2.2.2 [110/3125] via 172.16.8.1, 00:41:22, Serial1/0
3.0.0.0/24 is subnetted, 1 subnets
C 3.3.3.0 is directly connected, Loopback0
O E2 5.5.5.0 [110/20] via 172.16.9.253, 00:40:52, Serial1/1
O E2 6.6.6.0 [110/20] via 172.16.9.253, 00:40:52, Serial1/1
C 172.16.9.252/30 is directly connected, Serial1/1
C 172.16.8.0/24 is directly connected, Serial1/0
O 172.16.8.1/32 [110/1562] via 172.16.8.1, 00:41:31, Serial1/0
C 172.16.10.0/24 is directly connected, FastEthernet0/0
O 172.16.8.2/32 [110/3124] via 172.16.8.1, 00:41:31, Serial1/0
O E2 7.7.7.0 [110/20] via 172.16.9.253, 00:41:01, Serial1/1
O E2 192.168.4.0 [110/20] via 172.16.9.253, 00:41:01, Serial1/1
R3#
04-17-2008 07:09 AM
The Ethernet segment between R5 and R1 seems to have a high latency.
From R5 to R1 the traceroute reports
892ms is quite high for a LAN connection.
Then from R3 to R5, your first hop via the 128k Serial
a little in the high size, it seems you are facing bursty traffic
but when it reaches the LAN segment.
That's over 2 seconds hence causing the request time out.
I suggest you monitor the traffic on those links for saturation. Do you have any network monitoring tool ?
Edit:
I also noticed you are experiencing assymetrical routing.
The path from R5 to R3 goes via the OSPF Area 0 backbone (Frame-Relay) while from R3 to R5 goes via the Serial 128kbps OSPF Area 1.
You need to troubleshoot the configuration there.
04-17-2008 07:23 AM
Edison thanks for the reply. On the assymetrical routing, what would be the best approach to troubleshoot that config?
04-17-2008 07:39 AM
You need to determine why a path is chosen over the other path. Plenty of things to list, that's how your troubleshooting skills come into play.
It seems this is a lab and not a production network, huh ?
04-17-2008 07:41 AM
yup it is a lab so although not mission critical, it would be nice to understand the reason behind it.
