04-17-2008 05:33 AM
Hello.
My client needs to add another vlan to the CSS because he is getting short on ip address. So he decided to add vlan 5, removed the default route to 192.168.12.1 and added two static routes.
However nothing is working now and I can't figure out why.
The initial config was:
!*************************** GLOBAL ***************************
ip route 0.0.0.0 0.0.0.0 192.168.12.1 1
!************************* INTERFACE *************************
interface 1/1
trunk
vlan 12
interface 1/2
admin-shutdown
!************************** CIRCUIT **************************
circuit VLAN12
ip address 192.168.12.22 255.255.255.0
!************************** SERVICE **************************
service www-hux1
port 80
protocol tcp
ip address 192.168.12.24
keepalive type tcp
keepalive frequency 10
keepalive port 80
active
service www-hux2
ip address 192.168.12.25
port 80
protocol tcp
keepalive port 80
keepalive type tcp
active
!*************************** OWNER ***************************
owner HS
billing-info "ahp"
email-address hugo.soares@ahp.pt
content rule1
protocol tcp
port 80
add service www-hux2
vip address 192.168.12.27
add service www-hux1
balance aca
active
In the new config this is what's different:
ip route 192.168.5.0 255.255.255.0 192.168.5.1 1
ip route 192.168.12.0 255.255.255.0 192.168.12.1 1
interface 1/1
trunk
vlan 5
vlan 12
interface 1/2
admin-shutdown
circuit VLAN5
ip address 192.168.5.20 255.255.255.0
circuit VLAN12
Can you see what's wrong in here?
I almost forgot to teel that the default gateway of real servers is the CSS
Joao Carvalho
04-17-2008 05:54 AM
Ok. I think I got the problem. The destination of the packet sent by the CSS is a public ip address and none of the static routes matches that.
Now my problem is how can I influence the next hop based on source ip address, in a CSS?
Joao
04-18-2008 10:03 AM
I put two default gateways:
-ip route 0.0.0.0 0.0.0.0 192.168.12.1
-ip route 0.0.0.0 0.0.0.0 192.168.5.1
I saw this solution in several configs, but I can only ping 192.168.12.1
Any sugestions?
