Upgrading CUE problems
Apr 17th, 2008
I am trying to upgrade CUE from -
- application mode: CCME to CCM
When l try to carry out the following command, i receive this error message -
se-10-115-254-2# software install clean
% Invalid input detected at '^' marker.
I have tried this with the config attached below.
Any help would be grateful.
James
JAMES WEST Thu, 04/17/2008 - 06:59
Hi Rob,
Thanks for getting back to me on this. When i enter the conf t from CUE i do not see the software command - see below -
se-10-115-254-2> conf t
Enter configuration commands, one per line. End with CNTL/Z.
se-10-115-254-2(config)> ?
backup Save data to a server
ccn Telephony application
clock software clock
default Return a configuration value to its default
end Exit from configure mode
exit Exit configuration mode
groupname Group descriptions and accounts
hostname set the system name
ip internet protocol
log System event messages
no delete configuration command
ntp Network Time Protocol
privilege Privileges
username User descriptions and accounts
voicemail voicemail application
se-10-115-254-2(config)> software download server url
miqbal_786 Thu, 04/17/2008 - 07:25
try this it should work
software download clean url ftp://ftp-ip address/cue-packagefile.pkg username "ftp-username" password "ftp-password"
Rob Huffman Thu, 04/17/2008 - 07:34
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi James,
Did you first do a Backup? I'm not positive that coomand is available until after the Backup has been completed.
Hope this helps!
Rob
JAMES WEST Thu, 04/17/2008 - 08:05
Hi Rob,
I am just breaking up on annual leave for a couple of days, so l will try this when l get back in the office.
Once l have tried the back-up l will update this post.
James
JAMES WEST Tue, 04/22/2008 - 23:54
Hi Rob,
I have successfully backed up my CUE config, but when l come back online l am still unable to get the software command in CLI.
On the URL it mentions that going from CME to CCM or vice versa is not supported, l would still think that l should be able to get the software command to try and upgrade the version of software that l do have though.
Any suggestions/thoughts?
James
Rob Huffman Wed, 04/23/2008 - 06:31
  • Hall of Fame,
    Founding Member
Hi James,
I'm sorry, I completely missed the fact that you are trying to change from CME to CCM. you are probably looking at a re-install here :(
If your system is already configured, you cannot change the license type from Cisco Unified CallManager to Cisco Unified CallManager Express. To make that change, you must reinstall and reconfigure the system. The data cannot be restored.
However, you can change the license type prior to running the initialization wizard.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel2_3/install/upg_lic.html
You cannot move the CUE config between CME and CCM. You will need to order the proper License for use with CCM. Have a look;
Your system probably came with a License like this for CME (Note the CME at the end of the part#);
Cisco Unified Communications Manager Express
12-mailbox package: SCUE-LIC-12CME=
What you really need is a License like this for CCM (Note the CCM at the end of the part#);
12-mailbox package: SCUE-LIC-12CCM=
From this good doc;
Upgrading or Downgrading the Cisco Unity Express License in the Same Version
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel3_1/installation/guide/upglic31_ps5520_TSD_Products_Installation_Guide_Chapter.html
CallManager for Cisco Unity Express Configuration Example
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_configuration_example09186a0080289ef0.shtml
Hope this helps! Sorry James.
Rob
JAMES WEST Thu, 04/24/2008 - 01:30
Hi Rob,
Thanks for getting back to me on the upgrade of CME to CCM CUE.
What l was trying to set-up was in a lab scenario for me to test & play with CUCM versions, so no harm done.
Thanks for all your help with this post.
Cheers,
James
Christophe Villers Fri, 06/06/2008 - 02:02
IF I didn't run the configuration wizard how can I change from CCM to CME ?
Kind regards,
`tophe
JAMES WEST Fri, 06/06/2008 - 02:26
Hi 'tophe,
I have not tried the suggestion on one of the above posts -
You may want to try this and see if downloading a CCM file and trying a re-install works?
Let me know how you get on.
James
