fcanalyzer remote
Apr 17th, 2008
Have anyone used successfully the fcanalyzer remote command?. I have configured the mds and the ethereal rpcap interface as explained in the documentation but no joy.
Edmundo
ebodero Fri, 04/18/2008 - 00:55
Thanks for the reply. I am using 1.3.6. When I try to configure Etheral it cannot connect to the MDS. There is connectivity between the PC and the MDS.
Edmundo
inch Fri, 04/18/2008 - 14:22
Do you have any IP Services line cards in your switch?
Cheers
Andrew
ebodero Sat, 04/19/2008 - 07:24
Thanks for your reply.
Yes. I have the IPS-8.
Edmundo
inch Mon, 04/21/2008 - 02:41
G'day,
are you trying to remote fcanalyzer to a device which is on the same subnet as a port on your IPS or have a static route moving traffic through to your remote machine via a IPS port? (I suspect yes :)
I'm not sure of a work around but one of the Cisco guys might know a work around on here or you should log a TAC case :)
Cheers
Andrew
ebodero Wed, 04/23/2008 - 04:50
Hi Andrew,
Thanks for the ideas. Unfortunately I don't have the MDS under smarnet so I cannot open a TAC. Do you have it working?
inch Mon, 04/28/2008 - 16:32
G'day,
Unfortunately I could not get it working to a subnet which was being sent over a IPS port :(
The only way around for me was to have a workstation not on the same subnet as those on used by the IPS.
Cheers
Cheers
Andrew
ebodero Thu, 05/22/2008 - 04:52
No. I gave up. I tried with different switches and son-os but no joy.
Edmundo
Trending Topics: Storage Networking
