User Privilege in PIX 515
Apr 17th, 2008
I had created one user with privilege level 2 on PIX 515.
Level 2 privileges given are:
privilege show level 2 command running-config
privilege show level 2 command xlate
privilege show level 2 command version
But the user is not restricted with only the priviliges given.
He is able to enter configuration mode and modify.
The above configuration worked fine with two other PIX firewalls.
What might be wrong going on with this firewall? Please suggest.
Helpful posts will be rated.
rmeans Thu, 04/17/2008 - 11:41
What do you AAA commands look like? Are you doing AAA authorization?
