Guest VLAN setup on WLC526
Apr 17th, 2008
I'm trying to setup a WLC526 with two WLANs, one for the internal corporate network and one for guest access. I have the internal corporate network WLAN configured and working fine. All users get IP addresses from the DHCP server and can access network resources.
The guest network has me confused. I can create the WLAN and SSIDs. Machines can connect to the WLAN, but there is no DHCP and no internet access.
I'm guessing I've got a problem with the guest subnet not routing correctly. I'm fairly new to the routing part of networking, so I'm at a loss as to where to go next. Am I looking at setting up VLANs on the switches (3 Com layer 2 switches) or a Super Scope on the DHCP server for having multiple subnets on the same physical segment? If it helps the router on this network is a Cisco 2821.
