dsl, lan - wan - connection
Apr 17th, 2008
hi there,
i got a 1841 router and i have a dsl - line. i get a public ip, but i do not have access to the internet. i have no idea why... can anyone help me? thanks a lot.
actual config:
Current configuration : 1964 bytes
! Last configuration change at 19:27:35 METDST Thu Apr 17 2008
version 12.3
service password-encryption
hostname pfistyle
boot-start-marker
boot-end-marker
enable secret 5 xxxxxxxxxxxxxxxxxxxxxx
clock timezone MET 1
clock summer-time METDST recurring last Sun Mar 2:00 last Sun Oct 2:00
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
ip name-server 193.x.227.3
ip name-server 195.x.56.5
ip name-server 194.x.230.53
vpdn enable
vpdn-group pppoe
request-dialin
protocol pppoe
no ftp-server write-enable
no virtual-template subinterface
interface FastEthernet0/0
ip nat inside
ip tcp adjust-mss 1452
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface ATM0/0/0
mac-address 0013.199e.2e29
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
hold-queue 224 in
pvc 8/35
encapsulation aal5snap
pppoe-client dial-pool-number 1
interface Virtual-Template1
no ip address
interface Dialer1
ip address negotiated
ip directed-broadcast
ip nat outside
encapsulation ppp
no ip route-cache cef
no ip route-cache
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap chap callin
ppp chap hostname [email protected]
ppp chap password 7 xxxxxxxxxxxxxxxxx
ppp pap sent-username [email protected] password 7 xxxxxxxxxxxxxxxx
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
dialer-list 1 protocol ip permit
control-plane
line con 0
password 7 xxxxxxxxxxxxxxxxxxxxx
login
line aux 0
line vty 0 4
login
line vty 5 15
login
ntp clock-period 17178794
ntp server 134.93.132.118
ntp server 129.132.2.21 prefer
end
Kenneth Mohammed Thu, 04/17/2008 - 10:09
  • Silver, 250 points or more
I see you have nat specified on your lan and dialer interfaces, but there are no nat translation statements in your config..I think you need to configure nat to translate your inside addresses to a public routable IP.
Try adding this and see if it works:
ip access-list extended nating
permit ip 192.168.1.0 0.0.0.255 any
permit ip any any
route-map NAT permit 5
match ip address nating
ip nat inside source route-map NAT interface Dialer1 overload
and of course also make sure your pc is using the correct ip and subnet mask, as well as default gateway, as I see that you also dont have the router providing dhcp services.
hope that helps...
