CSM 3.2 & SUP720 compatibility
Are there any compatibility issues with ver 3.2 CSM code with the SUP720? My two CSM's in different chassis were working and after upgrading from SUP2's to SUP720's I cannot get FT to work. Both CSM's come up as active active and I have to shut one down to get server connectivity.
I want to verify before I upgrade CSM's to 4.2.
Syed Iftekhar Ahmed Thu, 04/17/2008 - 23:29
you can run CSM 3.2 code with 720.(
IOS 12.2(14)SX1 or CatOS 8.2.1 and greater needed)
Could you please check that CSM FT vlans are configured on both switches.(If vlan X is FT vlan then make sure that "vlan X" command exists on both switches.)
