EVM-HD-8FXS/DID
Apr 17th, 2008
Hello I have router 3825 with this:
2 PVDM2-64 ON BOARD
1 NM-HDV2-2T1/E1 (into 4 PVDM2-64)
1 VWIC2-2MFT-E1
I need set up EVM-HD-8FXS/DID into 2 EM-HDA-6FXO
I have transcoder 36 maximun session and 16 maximun conferences. My question is what I do need able to works fine?. do I need more DSP? This could this affect the performance of the team? if is true do I need more memory?
The NM-HDV2-2T1/E1 are completely works.
My Sh ver
Cisco 3825 (revision 1.2) with 486400K/37888K bytes of memory.
Processor board ID FTX1133A2BC
2 Gigabit Ethernet interfaces
31 Serial interfaces
4 Channelized E1/PRI ports
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
500472K bytes of ATA System CompactFlash (Read/Write)
thanks
