CME 4.3 and CUE 3.1.2
Apr 17th, 2008
My old system was
CME 4.2 and CUE 3.1.1
I have no problem with them
I upgrade to
at the same time
PROBLEMS ARE;
1)MWI does not work, I test it with 7911, 7906, 7941, ...
Is it reletad with CME or CUE?
2)Voice Wiewexpress does not record-play
propmts
What do you recommend?
Return back-to old versions?
Paolo Bevilacqua Thu, 04/17/2008 - 11:37
CME 4.3 is at the very first release. I would not deploy it yet unless there is a compelling reason making me loose business if I don't.
