CS 3.0.6?
Answered Question
I'm trying to update our LMS components...I know CS 3.0.6 is out, we're running 3.0.5. When I do the software update it downloads updates for all the components except for CS...and when I check for updates on CS alone it says no updates are found...but when I try to install updates for other components it says I need CS 3.0.6. Do I have to download this update manually from somewhere else?
Correct Answer by Joe Clarke about 9 years 1 week ago
The CS 3.0.6 update contains crypto code, and cannot be downloaded like other Service Packs. To get it go to http://www.cisco.com/cgi-bin/tablebuild.pl/cd-one-3des .
Overall Rating: 5 (1 ratings)
