ASA Clientless SSL VPN connections
Apr 17th, 2008
Is there a way to modify the default behavior of the automatic logouts? I have the user set for 1 simultaneous login. If you try to login with that same account again elsewhere, the first logged in user's connection is forceably closed. I would like it so if the login is used the first time and then another person tries to use the same one, the second person is just denied and the first person is not effected. Is this possible to change?
