CSM 3.1 and LMS 2.6 on same server
Apr 17th, 2008
Hi all
First qn, is ok to install CSM on the same server as LMS?
I have installed CSM 3.1 on the same server as LMS 2.6, installation went fine but now i cant access LMS as CSM has now taken the port 1741 which was meant for the LMS Http access, how can i be able to access both applications ?
Stupid qn yes, but when i read the prerequietes , i didnt see any issues or maybe i missed something . Any help will be highly appreciated
MM
Joe Clarke Thu, 04/17/2008 - 12:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
LMS 2.6 and CSM 3.1 cannot be installed on the same server. Such a configuration is not supported. However, even when installed on separate machines, you can still integrate the two DCRs, and use Single Sign On across both servers.
emaamur2006 Fri, 04/18/2008 - 01:34
Hi Joe
One more qn, If i use another server for CMS, i will need to install common services on it, can i use the same version, CD (License) for common services that i have on my current LMS ? I mean, would i have some issues with licensing ? Must i buy another LMS, that is Common services, as i can buy it as a standalone ?
MM
emaamur2006 Fri, 04/18/2008 - 04:40
I have unistalled CSM but i still have some issues accessing LMS, when i browse it , it still goes to CSM, although i have uninstalled it. I can access Common services and resource manager from the server itself but cant see any of the other components of LMS
Any idea how i can go around this, i know LMS is still there but i cant access some of the applications
Thanks in advance
MM
Joe Clarke Fri, 04/18/2008 - 07:47
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You will need to first uninstall BOTH CSM and LMS, then reinstall LMS from scratch. You could then restore any previous good LMS backup.
Joe Clarke Fri, 04/18/2008 - 07:51
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You will need to install Common Services on both servers. Common Services is unlicensed, but CSM has its own license. So you will need a license for LMS, and a license for CSM. These should have been included when you purchased each bundle.
