Jaime Valencia Thu, 04/17/2008 - 18:13
the PSTN only handles PCM so there is really no choice, that's why when you make a call it uses a DS0 which are 64 kbps. it uses G711
javalenc
if this helps, please rate
Sushil Kumar Katre Thu, 04/17/2008 - 21:44
As mentioned correctly by Javalenc, G.711 is always used for PSTN calls - 64Kbps consuming one channel for each call.
>> Sushil
Eric Krieger Fri, 04/18/2008 - 00:03
In addition to above, if you're after the used codec between the endpoint (IP Phone) and VoiceGateway (VG) (on your LAN/WAN), the Region setting of the Phone and VG in CallManager *and* configuration on your VG(codec class) determines the used codec.
Eric
