Documentation for quality manager and voip recording
Apr 17th, 2008
Could some one point me to a user level document on quality manager for express?
Also a similar one for monitoring and recording. Thank you
rajan-sbc Sun, 04/20/2008 - 18:19
Could you clarify if these products are for express and which version? Or these are for UCCE and whcih versions? Thanks.
Jonathan Schulenberg Sun, 04/27/2008 - 08:10
They are OEMed from Calabrio. I work with them in the UCCX space; however, I believe Cisco is using the same tools for the enterprise space as they do with CAD/CSD/CDA. You can connect with your local Cisco SE to confirm.
