Etherchannel will not come up on Catalyst 6509
Answered Question
Apr 17th, 2008
I am connecting to core switches together via etherchannel on their 10G ports
I AM Running s72033-ipservices_wan-vz.122-18.SXF9.bin on THE 2 6509s for some reason the 10G ports on core b will not come up. Config listed below. I do a no shut and it still says shut down
Core A
interface TenGigabitEthernet9/1
switchport
switchport mode trunk
switchport nonegotiate
no ip address
channel-group 1 mode on
interface TenGigabitEthernet9/2
switchport
no ip address
interface Port-channel1
description Etherchannel link to Core B
switchport
no ip address
Core b
description Etherchannel link to Core A
switchport
shutdown
no ip address
switchport
shutdown
no ip address
description Etherchannel Port to Core A
switchport
no ip address
Correct Answer by Istvan_Rabai about 8 years 10 months ago
Hi Keith,
Do the trunks come up as standalone trunks without configuring etherchannel?
Please try to do this first of part of the troublesghooting process.
This way we can isolate if this is an Etherchannel problem or it is something different.
Please inform us about your experience.
Istvan
Overall Rating: 4 (2 ratings)
Jon Marshall Thu, 04/17/2008 - 14:45
Your physical ports on Core b - they are in a "shutdown" state. Is this a typo ?
Jon
keith.k.quaye Thu, 04/17/2008 - 14:50
No Jon that is the crux of my problem when I go into the inteface and do a no shut it stays shut and thats what the current running config looks like I am scractching my head trying to figure out why.
lamav Thu, 04/17/2008 - 17:20
Hi:
For EtherChannel to come up, make sure:
All ports are configured with the same speed and duplex settings.
All ports are in the same vlan.
The same vlans are being allowed on each of the trunk ports you would like to make part of the channel.
Both switches are in the same VTP domain.
Check those things first.
Victor
Correct Answer
Istvan_Rabai Thu, 04/17/2008 - 21:20
Hi Keith,
Istvan
keith.k.quaye Fri, 04/18/2008 - 12:26
Istvan,
I did what you suggested and even went further I reseated the card then I took the etherchannel config off the card. It came up as a stand alone trunk. So then I redid the etherchannel config and it came up.
lamav Fri, 04/18/2008 - 12:30
Keith:
So are you saying its up now?
If I had ot take an educated guess, I dont think reseating the cards fixed anything. I would say it was bouncing the etherchannel config.
VL
keith.k.quaye Fri, 04/18/2008 - 12:36
VL
Yes it is up and I agree with you that was just as a sanity check since I couldn't get the physical interface to unshut it kept saying it was shut down and I wanted to make sure it was recognizing the xenpak.
Keith
